I need to install my new soil pipes but the foundations are in the way.
In the above picture my ic base is under the piece of board, the outlet with the bigger spirit level will be a vertical soil pipe up the side of the house, the smaller spirit level is the downstairs toilet.
As you can see above I can't get the pipes against the brickwork due to the foundations, building inspector has said I can't have bends in the wet part of the pipework so I need it to go through the foundation.
I'm proposing to cut the foundation out between the 2 levels in that second picture, install my 110mm pipes inside some 160mm pipe to the rest bends then shutter the side of the trench and refill with concrete.
Will the above work and will removing that 2ft section of foundation weaken the extension? I need to know quickly so I can get on and get it filled in
Chris
Chris
