We have one in our downstairs toilet that works fine apart from a bubbling? noise after it has stopped doing its pumping. Usually you can't hear it as the cistern is filling.....
There is very little vertical drop from the top of the unit under the floorboards where the 22mm plastic pipe travels through the joists with a slight drop to a connector on the internal soil stack about 3 metres away. The angled joints I can see are all 2 x 45 degree fittings to make 90.
Is the noise a concern?
Thanks.
Thanks.
