- Joined
- 27 Jan 2008
- Messages
- 28,360
- Reaction score
- 3,451
- Location
- Country
I have to agree with you. I looked at plug in chargers, this
cost £270, plugs into a 32 amp socket, charge rate selectable 8A, 10A, 13A, 16A, 20A, 32A I personally don't like the idea, far better to have a dedicated EV charge point, but this does show how cheap they can be.
No details saying if 6 mA DC trip, loss of PEN trip, if built in RCD or not, seems loss of PEN rare, but built in RCD and 6 mA DC detection reasonable standard.
So with a TN-C-S (PME) supply there are basic three options, make the supply TT, use a small earth rod as a reference point, or have it auto disconnect if the voltage is not within 207 to 253 volt. The latter seems an easy way out, the supply is 230 volt +10%. / -6% and the volt drop in the property is limited to 5%, so voltage has to be 205.5 to 253 volt.
So a 47.6 volt window, but loss of PEN will only cause over or under voltage if not balanced, it could with the multi-earth rods stay within the limits for a long time, and of course the reverse a local solar panel could tip the balance with over voltage, and machinery starting could tip the balance with under voltage.
I only know one guy with an EV van, and I have seen it at the side of road too many times, range was 110 miles milk round 64 miles, it should do that easy, even with a 3.5 kW charger. He says he never uses heater, and he does not drive fast, he says gauge shows well over half charged when he has finished the round, the problem is travelling from Wirral to North Wales after round has finished in the main getting up the Aston Hill. Most the time he makes it home, and he has not worked out why on the odd time he doesn't.
What's the betting it was not fully charged, some thing stopped it fully recharging.
Does not need to be a car or van, my e-bike has the same problem, normally from Llanfair to Welshpool and back still shows ¼ charge or more, but last time out, daughter rescued me, OK could have in fullness of time peddled home, but for some reason battery was not fully charged.
But with a car you can't fold it in half and stick it in the back of another car. Or peddle it home.
cost £270, plugs into a 32 amp socket, charge rate selectable 8A, 10A, 13A, 16A, 20A, 32A I personally don't like the idea, far better to have a dedicated EV charge point, but this does show how cheap they can be.No details saying if 6 mA DC trip, loss of PEN trip, if built in RCD or not, seems loss of PEN rare, but built in RCD and 6 mA DC detection reasonable standard.
