- Joined
- 18 Feb 2007
- Messages
- 1,400
- Reaction score
- 79
- Country
I purchased and installed an external Double socket from Screwfix. The back box has two Earth connections. When checking closely these earth connection have NO continuity with the Earth terminals on the sockets. I thought initially that continuity would be established when the sockets were installed in the back box via the location screws, however when checking the earth continuity I found that not to be the case. I reconnected the Earth wire from the supply cable directly to the socket earth terminal to establish continuity.
The question is, did I do right? I can see no reason for the Back Box terminals to exist as using them does not give an earth to the Sockets. Maybe the IEE Regs demand that NO Earth should be made for the External sockets as items like garden electrical equipment are usually double insulated and not earthed but of course I may want to use domestic equipment on a temporary basis which are not double insulated and as such require an Earth continuity for Safety reasons.
I would welcome comments from some IEE Regs knowledgable Sparky.
My thinking is that the design of having an earth terminal which serves no earthing purpose is suspect and providing it for use could be dangerous in that it provides an Earth terminal which does not earth the sockets if used.
