Gas Pipe Routing
25 May 2022
I have been advised that the gas pipe running within an internal wall to my CH boiler should be rerun outside/on the surface of the wall. Can anyone tell me if this is correct, please?
Would probably be better suited in the plumbing and heating sub-forum - I’ll report and see if mods can move.
Can you define running in an internal wall?
Thank you. I am new to the site.
Our boiler is in an upstairs cupboard the main gas supply pipe running up to it is inside a stud partition on the ground floor. The work was done by a gas safe engineer 4 years ago but I am now told that the pipe should be rerouted onto the outside face of the wall to satisfy current standards. Before I wnet to the expense of getting this done I just wanted to be sure that it was infact required.
  • Thanks
Reactions: CBW
It would depend how it is currently, if it’s in a purpose made duct, then it’s ok, there are other methods too. Who said it had to be moved/re-routed?
It is not in a duct it is closed up behind the plasterboard. The advice came from the engineer who did the annual boiler service.
  • Thanks
Reactions: CBW
Perhaps if it’s installed as per the attached, the there’s nothing to worry about, and perhaps show this if it’s questioned again
