I'm constructing a 6ft x 3ft ledge and brace garden gate using 15mm thick tongue and groove boards and 40mm thick ledge and bracing. I've seen a number of youtube clips which show joiners constructing such gates by screwing the boards down from the back of the gate rather than the front for security reasons i.e. the screwheads are visible from the back of the gate.
If I was to use a 4 x 50mm long screw and screw down the boards from the back that means only 10mm of the screw would be holding the boards. Would that be an adequate screw join?
I could screw in from the front and then apply filler to the holes but the gate is only going to be stained and not painted so the filled holes would show up as I find stains don't cover filled areas very well.
Any advise appreciated.
