Hello all, what is the correct cable to use for connecting a 6kw induction hob to a standard cooker switch socket (cooker switch and a single socket), which is fed by a 32A connection? There is an oven also connected to the single plug socket on the above.
Would 2.5mm T+E suffice (rated at 27A I believe), or or should it be 4.0mm T+E ?
Thanks in advance for any advice.
