- Joined
- 2 Dec 2004
- Messages
- 711
- Reaction score
- 8
- Country
Ah no, but most of the youtube videos are so I guess that's where I picked up that term from.Are you American?
Firstly, he is starting with what appears to be two planed boards or plywood which have rough cut edges. In the UK hardwood timber typically is suppled rough sawn, so you have NO reference face or edge to work from. That's why you use a planer to get flat to start with. It can't be done safely with a circular sawSo this doesn't work like he shows?
Yes. That's how mine were madeI'm not sure of the rules , but you may need to use food safe glues etc - for anything in contact with food
Crikey! You're showing your age, ther, @ETAF. One of my apprentice jobs was to keep the shop supplied with enough pearl hide glue (and rabbit skin glue if they were doing leather), but by the time I started animal glues were only being used for veneering jobs. Joints were always done with CascamiteI remember we had to join 3 bits of board together at School carpentry , using hot animal glue ... and used ALL hand tools, planes etc
Yep, late 60's early 70's at Secondary SchoolCrikey! You're showing your age, ther, @ETAF.
Seriously, if you are starting out you could probably get by with a portable (i.e. hand held) power saw, something like a 190mm blade tool, if you already have one. @ETAF 's recommendation of a track saw is also good (as a cheaper way of getting started). The keu is to fit the right blade. Long term, though, if you get into production you will need a table sawttps://www.amazon.co.uk/What-Wood-That-Manual-Identification/dp/0854420088@JobAndKnock thanks. I found a video review of the Titan and see how it works now. Does seem easier than the table saw method. But I would still need a table saw for ripping the planks length ways won't I?
Yes, but you need to know what tools you are going to install in your shed to plan it, surely?Anyway, getting ahead of myself, tooling up will be a later topic once I have a workshop built which is months away still.
It's nowhere near as easy as it is to source softwoods. I'm in the north west, so I know who my local suppliers are. If you are in the NW or NE say so and I'll point you at a few good merchants. In somewhere like London I'm aware of one or two firms like South London Hardwoods, but other than that it's a case of Google and phoning. This is not the sort of stuff you can buy readily on the 'net IMHO. It sounds from the foregoing that you are looking for a percentage of tropical hardwoods for accents, and they have always been a specialist product. If you don't know what you are looking for, maybe you should get hold of a book by Herbert Edlin called "What Wood is That?" (second hand is cheaper, don't spend more than £25). In the front of the book is a set of actual wood veneers, 40 in total, which should give you some idea about the different commercial species look like, colour, texture, etc. Well worth the money and used required reading on some college courses (e.g. furniture manufacture, cabinetmaking, etc)Any comments on how easy it is to source hardwood planks?
Seriously, if you are starting out you could probably get by with a portable (i.e. hand held) power saw, something like a 190mm blade tool, if you already have one. I'd certainly look at @ETAF 's suggestion, too. The main thing is to team the saw up with the right blade. Eventually you would need to go to a table saw, basically on grounds of speed, but to trial an idea it isn't that essentialttps://www.amazon.co.uk/What-Wood-That-Manual-Identification/dp/0854420088@JobAndKnock thanks. I found a video review of the Titan and see how it works now. Does seem easier than the table saw method. But I would still need a table saw for ripping the planks length ways won't I?
It's nowhere near as easy as it is to source softwoods. I'm in the north west, so I know who my local suppliers are here and in the north east. In somewhere like London I'm aware of one or two firms like South London Hardwoods. Other than that it's a case of Google and phoning. It sounds from the foregoing that you are looking for a percentage of tropical hardwoods, and they have always been a specialist product so you probably won't get what you want at an economic price, over the 'net. If you don't know what you are looking for, maybe get hold of a book by Herbert Edlin called "What Wood is That?" (second hand is cheaper). In the front of the book is a set of actual wood veneers, 40 in total, which should give you some idea about the different commercial speciesAny comments on how easy it is to source hardwood planks?
Im think Walnut, Maple predominantly, and then maybe some Cherry and others later once I get more experience. Im in the W.Mids by the way.It sounds from the foregoing that you are looking for a percentage of tropical hardwoods for accents
Ah ok. That makes sense then why all the US videos have these really long solid looking fences on their table saws, but all the ones I was looking at for sale here have quite short flimsy looking fences.Secondly he is working with what is called a through type rip fence. Technically, saws aren't supposed to be sold with those in the UK
Those long solid looking fences are a major reason why American forums have more than their fair share of stories about kickbacks. Kickbacks are sometimes caused by wood which bends away from the saw blade when it is cut, ending up jammed between the blade and the extra long fence. When that happens the timber can be thrown back at the operator at around 100mph. It's called a kickback - and because walnut is steamed to get that beautiful consistent colour, it is rather prone to this sort of behaviour. European short rip fences (the "short flimsy ones") are actually considerably safer to use because the fence doesn't extend past the blade, so if you are sawing timber which divides this way it can't get itself caught between the fence and the blade because there is no fence to trap it.Ah ok. That makes sense then why all the US videos have these really long solid looking fences on their table saws, but all the ones I was looking at for sale here have quite short flimsy looking fences.
That's because they often don't know about any other machines. Cross cuts are faster and more accurate done on a mitre saw; have you ever thought about how to crosscut a 16ft length of skirting or an 9ft length of rough sawn timber with a sled when you have an 10ft wide shop containing a bench, etc? Edge jointing? Did you know that other than some industrial users American DIYers didn't know what a planer/thicknesser was until maybe 10 years ago (they've been common in shops in Europe since before WWII). Cutting rebates and grooves? Never heard of a router? Believe me when I say that dado heads aren't the wonderous thing they are cracked-up to be, and that part of the reason Yanks use them is because they have access to cheap plywood and so have never bothered to learn how to make furniture other than by making grooves in planks. Take the riving knife and crown guard off and you've increased the risk of a pinch kickback (where the timber contains tensions which causes it to pinch the riving knife as it's cut - no riving knife and it will pinch the back of the blade instead - whilst the crown guard reduces the chances if you have a kickback of having the kicked back piece of timber thrown back into your face (it can still get you in the groin, though, if you are stupid enough to stand directly behind the blade) whilst simultaneously ensuring that you won't plant your hand on a spinning blade if you lose your balance and falling forwards, putting out a hand to stop your face hitting the saw bench (presumably because you were smacked in the face by a kicked-back piece of timber).Almost all the US videos I have seen, and they all make really great stuff, are using their table saws for almost everything. Cross cuts - they make a cross cut sled. Edge jointing - they make a jointing sled. For cutting rebates and grooves - they are removing the riving knife and making multiple passes to cut the groove or the rebate out usually with some sort of sled as well. Etc etc.
Only Americans could be so ignorant. The safest, fastest and easiest way to plane something is on... a planer! FFS a basic planer/thicknesser can be had in the UK for under two tons (see above), so why on earth would anyone want to get an only slightly cheaper thicknesser and build jigs for it? Proof that there are some people out there who would invent a square wheel, maybe...There's also tonnes of videos which say that a proper jointer or planer/thicknesser is not needed. The ones that do have a planer but not a jointer, make a sled for that too and use shims to get a flat plank. Some use a router against a flat edge template.
Both ignorant and stupid, but at least I can demonstrate that with a video (from the USA, no less!). If you have a kickback as your hand glides past the unguarded, riving-knifeless blade on your saw and you lose your balance, where can your hand end up? In the blade. Who will win that argument? The blade, every time, hands down...Oh also all the US guys seem to use the gripper push blocks on top of the piece, rather than a push stick from the rear.
Yes, I've seen that too many times over the years. When I've been on jobs with a black hat (i.e. as foreman) one of my many tasks was to stop such behaviour. I do it because I genuinely don't want people to have accidents, and in any case that sort of behaviour is frankly unnecessary. The fact is that if the main contractor's H&S man catches someone doing that there is normally hell to pay, or worse if an HSE inspector catches someone at that it'll be be fines all round (the operative, me as his i/c, potentially my employers and quite possibly the main contractor as well - the HSE is self-financing nowadays, so you can guess where all the money comes from). This is all good motivation to obey the regs - as well as keeping a workforce who can all count to ten on their digits, without the need to remove a boot and a sock...... I could barely keep looking as his fingers seemed only about an inch from the blade as he pushed it along, the guard had been tightened up so it was up out of the way too. Genuinely thought I was gonna witness some fingers flying through the air.
