Honey well thermostat
29 Jan 2022
New house got a combi boiler wireless Honeywell thermostat working fine.
I want to have remote access eg hive etc. Any advice or ideas please
thanks
This works fine and is paired with a rf thing near the boiler. Works fine but I need remote access
hanks
I don’t think that is compatible with the app, so you’d need a new kit altogether. So Hive, Nest, Tado, Honeywell (app compatible) et al.
If i buy the hive kit. Can i use the current transmitter that I have near the boiler.
No, you can probably use the wiring and that’s it. Honeywell and Hive are not compatible.
Get a honeywell t3r, excellent bit of kit.
The Honeywell T3r does not support remote access
No you will have to use the hive receiver (it is not a transmitter as you call it) , make sure you get the single channel Hive , you will have to swap the backplates and alter the wiring but a very easy job to do
