Hammerite white gloss radiator paint
23 Aug 2013
South
I’m going to soon take off our radiator in the front room to give it a paint and a flush as I’m sure there’s some sludge inside and probably a chunk of metal inside as I can hear it every so often
I want to give it a lick of radiator paint but has anyone had experience with the hammerite radiator paint?
Ideally I’d just replace the radiator but it’s imperial and will be a pain to convert to metric so that can wait until I get a plumber in and change all radiators and pipe work, but for now I’d like to paint it.
If hammerite radiator paint isn’t great is there another one you recommend?
measure it and post the sizes , you might be able to get a replacement a lot cheaper than you would think, painting it with anything just reduces the amout of heat it will radiate
The heat output being reduced is a concern.
It’s a type 22 radiator from new build back in 1999
Width: 1444mm
Height: 400mm
I do want everything metric at some point though because it’ll be easier and usually cheaper going forward but if you know somewhere reasonably priced that’ll be good to know for sure
Width: 1444mm
Height: 400mm
Width: 1444mm
Height: 400mm
Are you sure it is a type 22 ? if it is then painting it is a complete waste of time, if it is then this will fit
it’s a double convector but doesn’t have the nice grill covers and sides, isn’t that link you sent a normal metric radiator?
This is the radiator
rather than white, I favour satin finish in a colour to match the walls.
it is more durable and easy to clean than emulsion
I have never used that particular hammerite paint. I suspect that it is an oil based "enamel" type paint as opposed to the old skool hammerite cellulose based paints.
If you do not hang wet clothes on the rads, most oil based paints will be fine.
Traditional Hammerite is xylene based which means in practice that it can't be overbrushed, even once. I did try the radiator paint a good while ago and wasn't impressed.
I wasn't particularly aware of the heat retaining property though which makes complete sense!
John :)
Not saying you are wrong Ian, but I do find it hard to believe that a coat of paint will make any appreciable difference to the output characteristics. So far what paint to use, I did mine with a water based paint for woodwork, four years ago and they have been fine, no discolouration, no problem with heat transfer at all.
The spray is ok really - best if the aerosol is warmed in hot water first.
The brushing stuff is absolutely horrible - especially the hammer finish variety.
In Hammerites early days, they reckoned you could spray your fruit trees with waxoyl - 'kills aphids' I remember. o_O
John :)
It wouldn't be the end of the world if you just used oil-based undercoat then oil-based gloss.
Be sure to give it a sanding all over and prime any bare bits first though.
I too doubt that a couple of coats of paint would make that much difference. Most rads work via convection rather radiation and people seldom paint the reverse side.
