Fibre cement cladding tips?
9 Jan 2020
I'm seriously considering going the fibre cement board instead of timber for a small part-clad garden room (approx 15m^2 of cladding) on a 5x3m room (thanks to suggestions in a previous thread).
I've never worked with this material though I do have some samples, I have no 'feel' for how it behaves. I'd welcome any tips or experiences you've had but I do have a few specific questions:
- Cutting. I have a Dewalt 18V battery 184mm circular saw and I am ordering a mitre saw (leaning towards the Evolution with the multi-blade) can either of these be used with a special blade, or do I need a dedicated "wet saw". I see Screwfix have dedicated fibre cement blades but the 184mm one is £60 and listed as "coarse cut". If the Evolution mitre multi-material blades would work then that would be great!
- The ones I'm looking at now (CladCo) their installation guide says I should install a DPC/water-proof strip outside the battening between the cladding board and battens, particularly at corners and joins. This is separate to your breather membrane under the battens. I've been spending quite a bit of time looking into timber cladding and never seen this, the whole point is that water can get through but the air-gap provides drainage/ventilation. Not sure if this is different for cement boards or the manufacturer is just being extra cautious?
Get you're self a guillotine for cutting too length cleaner cuts also if doing on you're own gecko clamps are a second pair of hands
Whenever we work with cement based materials we have both the 9” and the mini grinder on the go. We usually fit a 300mm diamond blade onto our big Dewalt chopper for straights. Deffo need a grinder for angles.
This is the same sort of thing for cutting laminate flooring? Like https://www.toolstation.com/roughneck-laminate-floor-cutter/p37836 for about £50... I can see pro ones for 10X that!
I'd seem people make a jig for plank spacing but not those little clamps... pretty neat idea. Thanks.
Hadn't thought of using the grinder. Can see it being a bit slower and less precise but my job is not very large - we're talking a few dozen cuts not hundreds.
Guillotine would be cleaner - no burr. We generally use the grinder for angle cuts..
Like into the peak at a gable end, or more complex cuts? I was wondering why the guillotine would be a problem for a simple angle?
Also thinking about the inevitable rip you have to do on your top board and around window/doors. Sounds less fun!
Is a proper mask advised for cutting these even outdoors? Is it like cutting bricks?
Yep decent lam cutter will do we use the Hardie ones which are £ plus dust free also only worth buying blades for long rips and grinder as said is handy
