I am so confused here.if in constant heavy use use the full 100% charged to flat cycle
if in constant daily or weekly use rechage when flat
if in sporadic use leave around 65-80% charged and check every say 10-12 weeks and charge iff required
i aim for no more than 80% no less than 20% iff left unchecked for over 6 months
the reason for the wide 65-80% is some batteries only show 1/3-2/3- last 1/3 and others 1/4-1/2-3/4-last 1/4
Ok cool. There isn't a built in level indicator. The battery charging station has the level indicators.Go for 3 or 4 times a year assuming it's a li ion battery with a built in power level indicator on the battery
Only charge to 3/4 full when storing for a long time. Charge when 1/4 full when you insert into charger.Ok cool. There isn't a built in level indicator. The battery charging station has the level indicators.
It is slide on batteryis it a plug in battery with a stalk or a slide on battery
if your not sure tool / battery or charger catalogue number will help
indeed that's why i suggested daily to weekly even monthly use suggested full cycle flat to full charge but prolonged inactivity should be as aboveI thought lithium batteries should not be stored fully charged.
