Is it possible to disable light?
27 Sep 2011
Bought a powered bathroom mirror which I love.
To turn on the light strips, you press the red button on the mirror itself.
When not in use, the button stays red.
I find this annoying and don't want the red light always on
So I wanted to know whether it is possible to disable this?
I'd have to open up the mirror but before doing so, I wanted to ask whether this is remotely possibly?
We still want the mirror to light up but I don't want the red light always on when not in use
I would consider finding somewhere to fit an accessible mains switch for it - without the red light, you may have to rely on looking for the smudges, every time you want to turn it on! :)
Open the mirror and disconnect the little red bulb/led inside it.
It's may well not be quite as simple as that, since the 'red bulb/led' may well be inside (an integral part of) the switch, which may well not be (non-destructively) openable.
Of course, the OP may be lucky and find that the light is separate from the switch but I don't think I'd put much money on that!
I strongly suspect the "switch" is a capacitive touch sensor, beneath the mirrors surface - the LED could be a surface mount device on the PCB?
Edit:
The OP may be in luck; most of the sensors I have found seem to be modular, with built in illumination.
Example:
...being a module, it should hopefully be possible to remove and modify :)
It could well be - so perhaps not literally 'inaccessible' - but nevertheless possibly quite not as simple to 'disconnect' it as was seemingly being suggested. If it were as you describe, then I'm sure that you or I would manage to 'disconnect' the LED, but .....:-)
. If it were as you describe, then I'm sure that you or I would manage to 'disconnect' the LED, but .....:)
Sorry, just edited my post. Most touch mirror switches seem to be modular - which makes sense given their extra complexity.
Edit: The OP may be in luck; most of the sensors I have found seem to be modular, with built in illumination.
Example: ... being a module, it should hopefully be possible to remove and modify :)
Hopefully easy to 'remove' - but as for 'modify', aren't we probably back to my ...
..... may well be inside (an integral part of) the switch, which may well not be (non-destructively) openable.
Update: I opened up the mirror and I have attached pics of the switch which has the red led.
It is labelled as the 'touch swich' and it's in black it appears to be glued/siliconed in place.
3 white wires comes out of it and this goes to the 'power adapter' (in white)
@JohnW2 @RandomGrinch what are your thoughts?
It looks like silicone rather than hot glue?
Carefully remove the silicone/glue along the sides (leaving the backplate in place):
Then slide out the sensor.
Thank you.
I removed the silicone and slide out the sensor
I took a pic of the sensor (turned over)
If you disable the led, how will other people know where to touch the mirror?
Is this a business property? I have never seen a domestic property with a pin code lock on a bathroom door.
I wondered about that in post #3 - I *think* the etch in the mirror, that allows the led light through, should (hopefully!) also be visible when the LED is off - we will wait and see! :)
I also wondered about the code lock - (ex?) HMO?
