Odd lighting wiring
Yep you're getting stuck into the confused detail from OP too.
Assuming they are correct, the actual details provided by the OP seem clear and straightforward enough but, as I wrote, I'm surprised/confused by the fact that the 'permanently-on fan' was not mentioned until post #18 - which makes me 'wonder'(per my previous post) :)
Kind Regards, John.
Has doing this cured the problem with the light?
Nope! It's still slightly on, very faintly.
Sorry everyone for the confusion :LOL: In summary:
She noticed the light was slightly on so I had a look and took that photo. She hadn't noticed the fan was always on. I think maybe because it's very quiet.
I then thought the fan might have been wired incorrectly causing the light to always be on and then noticed it wasn't a timer fan even though it had 3 wires running to it. I switched SL and L so now the fan only turns on when the lights are on.
When the switch is off the light is still ever-so-slightly on.
So where did you switch the wires, in the fan or in the ceiling rose?
@Soong i don’t think you have yet told us the make and model of the fan.
You see, some fans have a function called “trickle”. The fan runs all of the time at a very low speed and , when it is triggered, it comes on to full.
If that is the case your change of wiring may have bypassed the trickle function.
So, make and model please. It’s probably on a label under the front cover.
While you are at it, post a photo of the fan connections.
Interesting. I've never ome acrcoss, or even heard of, such an animal! Can you tell us any examples?
Really?? You should get out more.
Here’s one
And the Vent Axia Svara, and many more
Really?? You should get out more. .... Here’s one
Thanks, but at that price I'm probably glad that I don't get out more!
I have to say that so many domestic bathroom extractor fans are so relatively ineffective even when running at full speed that i have to wonder what they achieve (beyond a high price and some 'gimmick value') when running at "a very low speed" :)
In the fan, simply because that was easier. Should I have done it in the ceiling rose?
Vent-Axia VASF100B. Which from what I can tell is the most basic of basic extractor fans.
