Bathroom Light and Extractor fan on same pull switch.
5 Sep 2022
I have a series of bathroom ceiling lights which are controlled on/off via a simple pull cord switch (10A). The extractor fan is also controlled via the same pull switch with no timer, so lights on/off and extractor on/off are together.
I would like to be able to isolate the bathroom fan separate to the lights as it is very noisy on a night or sometimes when you want to have a bath.
The existing lighting circuit is on an old wiring system, and there is no earth present on the pull cord switch housing, just the standard red/black into COM/L1. The extractor appears to come off a junction box from the lighting circuit but I haven't looked at it in detail.
Would it be a real pain in the arse to create a separate switch to isolate the fan? An electrician friend of mine said you could just add another pull cord switch for the fan, but I'm guessing it may be invasive work into the ceiling. For the record, I can't get "above" the ceiling in question.
It's highly unlikely you could alter the wiring without access to it !!
I can pull the junction box which feeds to the extractor fan through the hole for the ceiling light.
Likewise can pull plenty of cable through from the existing pull switch and have access via four ceiling hole lights, so could trace some cable back to a separate pull switch fairly easily.
What I meant was I can't climb above into a loft like I can for the bedroom lighting circuits.
Sounds like you may be able to do it without too much hassle. What conductors are present at the JB ?
it is very noisy
I can recommend you a better quality, modern, very quiet fan with a ball-bearing motor and isolating rubber mounts.
Please post a photo of your old fan.
Surely, when bathing, the fan should be running given the steam generated?
In my bathroom, I have a Xpelair fan with a humidistat built in. I am more concerned about moisture than "smells". That said I do have an over-ride switch if things are smelly.
Perhaps you just need a new fan? Some have two voltage settings, on the more quiet setting, less air will be extracted per minute though.
In my bathroom, I have a Xpelair fan with a humidistat built in. I am more concerned about moisture than "smells". That aid I do have an over-ride switch if things are smelly.
Presumably, it might me not seeing the forest for the trees, at first a new fan seemed a lot more work, but in hindsight it may be a wiser option.
I think it might be an Xpelair VX100
The Silent 100 range by Envirovent/Soler & Palau is much better
There are timer versions
Prices vary
For what it is worth, this is the fan that I have
It has been been more reliable than my (significantly) more expensive (larger diameter) Icon fan downstairs (which has switching/PIR/humidistat).
