I had some pipes to replace/reroute at my mum & dad's house today. In the past I've always shyed away from soldering and used compression fittings, but thought I'd give it a go this time. I swotted up on the web (clean with wire wool, paint flux on the pipe end, fit together, heat for 15-20s at the tip of the bright blue flame). How hard could it be?
The first problem was that the blowtorch flame kept "flaring", basically erupting into big orange flames. Not sure if it was because the torch (https://www.toolstation.com/gosystem-auto-start-blow-torch/p51854) didn't like being pointed down at an angle? Or was it too close to the work area perhaps, starving the torch of fresh air and sucking the hot air back in?
The second problem was that on the few (horizontal) joints that I did tackle, the solder just wasn't running into the joints, and was instead forming blobs and running off the pipe.
Any suggestions on what I might have been doing wrong with both issues?
Needless to say I went back to compression fittings, which was a shame as I'd really liked to have cracked soldering this time round, having last tried it 25 years ago with similar results.
