To stop them moving to where?non-shrink grout to lock everything into position.
As I made clear, I don't think it'd be an issue. However, if the OP wanted to, grout would eliminate any risk of movement. It'd also fix the cracked packer.To stop them moving to where?
Something was mis-measured somewhere - and if in doubt put it in lower and packing up is easier than the other way round. But a padstone's actual role is to reduce stresses on the wall immediately below the padstone. Packing up doesn't affect that function.My concern is how have they got the placement of the padstones so wrong? SE design was for the steel to be sat on the padstones not 50-60mm of paving slab, slate, steel shim or whatever else they could find to use as a packer. Is there no regs as to how much you can pack up?
It just doesn't seem right to me but that's a completely unqualified opinion.
I know they aren't going to fall down the main issue now is continued movement due to a cracked packer, 1 padstone not being cemented in place and some of the RSJ ends not being tied into the brickwork. I would rather try to correct now to avoid having issues later down the line. You may have just given me the solution, mess isn't an issue due to the house being empty.
But it must put stresses on the packing?As I made clear, I don't think it'd be an issue. However, if the OP wanted to, grout would eliminate any risk of movement. It'd also fix the cracked packer.
Again, movement to where?grout would eliminate any risk of movement.
The packers need to be either flexible (steel) or perfectly flat, otherwise the stresses induced will potentially cause them to crack (which is what seems to have happened in one place here)But it must put stresses on the packing?
Is there no regs about how high you can pack and/or the materials you should pack with?
Every pack up is different in both height and materials used
Downwards, possibly off level.Again, movement to where?
They are not going to move there is no risk, so it would be a complete waste of time.
Even the broken one?Lol. That beam won't be going/ can't go downwards. Have you seen what they are sitting on? It's compressed concrete, most likely as good as that padstone needs to be.
However, even if we assume the packing is unsuitable grout won't magically increase its bearing capacity or shear strength.
Put in in two piecesEven the broken one?
That's OK?Put in in two pieces
Diagonal shear is the concern with bearings and not vertical cracks - which are not created by the beam in the first place.That's OK?
Potentially just the plaster from it being covered over
