Hi all.
I've read conflicting things about how to do what I'd like to accomplish so thought I'd post my own question as everyone's circumstances are different so here goes.
I live in an end-of-terrace circa 1906 property with cavity walls. Both internal and external walls are of red brick construction, with the inner being plastered.
However, the back of the house gets minimal sunlight and gets cold, especially in the winter. My little girls bedroom is the coldest and her two exterior walls gets condensation building up which can turn to mould if I don't keep on top of things, which adds to the cold. I would like to make her bedroom warmer so I'm going to install insulated plasterboard just on those exterior walls and have them rendered, to at least stop the wall from getting so cold and condensation occurring.
My question is, can I use dot and dab to stick the plasterboard on to the wall (an article I read said insulated PB has vapour protection qualities and so can be used directly even if condensation is prevalent) or should I use battens and fix the PB on to this thus keeping it away from the wall? My only problem here is that I don't have a lot of leeway where depth is concerned, because of the bedroom door frame .
Any advice would be greatly received!
Thanks in advance.
Thanks in advance.
