- Joined
- 26 Jun 2022
- Messages
- 20
- Reaction score
- 0
- Country
Hello,
I wish to add a double socket and light to the understairs cupboard.
The CU is also in the cupboard. There is redundant 6A MCB with twin and earth attached from where I removed an old alarm system.
There is also easy rear access to a hallway socket which I believe is directly on the ring final circuit (two twin and earth cables going into it).
The light will be a 9w bulkhead light. I wish to use the double socket for charging a cordless vacuum cleaner (not sure what the draw on this would be, maybe 40w?) and running an ethernet switch (3w max).
My initial thoughts were to use the 6A MCB for the light (so if something trips the downstairs lighting I still have light in the cupboard) and then spur off the ring final for the double socket?
Although I think due to what I am intending to use it for, I could also run the socket off the 6A MCB and be well within safe load. Although I have read that is not best practice in case someone comes along and plugs two electric heaters into it or something?
Does that sound correct and safe?
