Sure, but it can contribute - by reducing 'adventitious' ventilation. Trad chimneys, leaky floors , etc.I can read very well. You are wrong to suggest that insulation causes poor ventilation.
I wasn't suggesting they don't need ventilation. Please don't twist my comment to suggest I ever said that.Houses need ventilation. Especially when water vapour is delivered inside them, from bathrooms and most expecially from drying clothes.
Modern standards do not negate that fact.
First and foremost, outside walls should be well insulated to prevent cold surfaces in the first place.Sure, but it can contribute - by reducing 'adventitious' ventilation. Trad chimneys, leaky floors , etc.
Modern houses have ventilation built in and do not require a regime to maintain it.
There's no suggestion that there was such modern techniques built in to the house in question, Quite the reverse.Apart from a regime of NOT closing and taping over ventilators, or turning off fans
Which some people do.
OK, but the thread was about the Rochdale house, and this incident.I was replying to "modern houses"
Not about the Rochdale house.
Really the only solution to these problems is forced, heat exchanging, permanently running ventilation. Permanently running means that the tenants cannot turn the ventilation fan off.
I agree, but it can take many, many months of a strict regime to dry out a saturated* house.Or effective dehumidifiers.
Too dry atmospheres also cause problems.No matter how well build and insulated, if you introduce too much moisture, mould will appear.
I love my dehumidifier.Or effective dehumidifiers.
There is a total ban on drying anything on radiators, or boiling without lids in this house. The only place indoors where items are allowed to hang to dry, is in the utility, where there is a dehumidifier and that runs the entire time until clothes are dry. No mould here at all, ever.
Set dehumidifier to run for 7-9 hrs (overnight) time dependent on what's been washed.
