Yesterday, some of the weaker MUXes began to pixelate, on the living room TV. Checking other TV's around the place, they were similar. Chimney antenna downlead, plugs in, in the loft, then goes all the way down to living room, where I have an 8-way distribution amp, that then feeds most of the rooms in the house.
This morning I got the binoculars out, to check the antenna, all looked OK, so I went in the loft to check where the downlead plugs in and the cause of the issue was obvious - there was water in the plug, from the recent rain. As a temporary fix, I fitted a signal booster, which has restored full operation for now. Hopefully it will last until the summer, when I will get an installer out, to fit a new antenna and downlead.
