Evening All.
Earlier this year the Controller/Timer packed in (Honeywell?) on our Combi Boiler.
I replaced it with a Hive Wireless controller.
Thinking back, I dont think i ever tested the heating when i fitted it since the hot water worked perfectly fine,
but turning the heating on this morning didn't work, The controller shows the heating as "on". But the heating is physically not working and i cannot figure out why. Both the old wiring panel and the hive panel had 6 poles with the same markings so i wired the hive into the same poles.
Some searching found some others with similar issues regarding the thermostat for the boiler. We do not have an external thermostat so can only assume theres one inside the boiler.
The heating has always been either "on or off".
