Rotary/dremel tool attachment for filing metal?
21 Feb 2019
I have to file down the edge of some door strike plates. Is there a rotary/Dremel tool attachment that would be able to do this please? Thanks!
the normal with stricking plates is to sink them in or move them with a bit off chiselling out or matchstick/hole filled with slithers and bradawl
exactly what surface or edge are you attacking ???
remember, it needs to finish ultra smooth to avoid friction 'jambing and wear
If it's the tab these can often be gently bent a bit to allow the latch to slide past.
I've even been mildly successful by polishing the striker plate and catch with a nylon scourer.
I'm trying to file down this edge, because the lock feature is curved and catches on it.
Thank you, I don't think using a scouring pad will work here and I can't seem to bend it, so filing it down is the only option.
another point
has the door been dipped or stripped as this can dissolve the glue and cause the door to drop
The easiest way for this one is to buy a small flat file from Homebase or whatever, put the keep in a vice and the job will be done in minutes.
Using round rotary tools will give a lump in the corners.
If you have a vice of course! :LOL:
You don't need a vice, John you can file it in situ in the jamb.
John :)
Understood Burnerman, no vice though!
Filing in situ can be awkward depending on the depth of the recess cut in the frame, and how much metal you need to remove......
How about one of these for Christmas?(y)
John :)
