HRM Wallstar Oil fired Boiler 12/14: Short Cycling or Normal?
Hi
I’ve recently moved into a property that has an oil fired Wallstar Boiler (12/14 model ?) that’s around 20 years old. It has a good service record and ‘appears’ to be working.
When it is being used for heat, the boiler fires up and heats up the rads quite quickly. Once the rads are hot, it then cycles on and off (approx 2 mins on and two mins off). The pump is running all the time, there are no lights other than the amber mains neon indicator and the heat valves (S-plan system) is on. The rads stay hot all the while.
Having just moved from a house that had a new gas boiler, it too cycled when the heating was on, but not this regularly.
My first thought is the boiler has reached temp and it is waiting for the water to cool before switching on again. It does appear quite effective in warming the rads quickly. I've looked all through the manual and an unable to find any information on the way it operates normally.
Hi
