wallstar oil boiler
Works perfectly ok through the day, but if left off overnight goes out on timer lockout on first start up. Reset and bleed the oil supply everything ok till next time it goes off overnight.
When boiler first installed the fire valve was seperate to the check valve, HRM have now made it a combined valve, have tried 3 from HRM all worked ok in normal operation through the day, but oil leaked back if boiler off more than 4 hrs.
Tested each valve after taking back out by standing on my bench, filling up with oil and sure enough oil leaked out after 4+ hours. Made all this information available to wallstar as in my opinion there is a design fault with them, no info back.
Any one else have this problem, as now running with no shut down overnight till weather better.
joander
joander
