Cruise Control Issues
It is sad to speculate about the poor fellow
But
Cases are known where drivers have claimed that their car ran away and would not stop.
Usually in an automatic
They had put their foot on the accelerator thinking it was the brake
And of course, the more they panicked, and the harder they pressed, the faster it went
Perhaps that happened.
The investigator said there was no sign that the brakes had been applied and the accelerator pedal was fully depressed.
I've heard that some people like to drive along on cruise control with their feet off the pedals.
"He didn't press the brake"... needs investigating. Maybe he panicked. Humans do human things.
I'd have to do some experiments, but I'm pretty sure my car ignores you if click it in to manual and keep trying to select a lower wrong gear with the paddles. But yes the poor chap should have tried the brakes or clicked it in to neutral.
I had a near miss with cruise control once, but it was entirely down to human error - not knowing where my feet were in relation to the pedals Because I’d had them flat on the floor.
Now I always hover my foor over the accelerator and have the side of my foot brushing the brake.
Once while in cruise control (not adaptive) on the motorway, my car started accelerating all on its own.
Turned out that the (heavy, rubber) car mat had slithered forward enough to be sitting on the edge of the accelerator pedal.
I'd put this extra mat over the fitted one, as the latter was developing a hole in it where my heel rested.
No matter how smart the engineer, a human end user can always do something stupid, unforeseen, or both.
After that, I just riveted an aluminium sheet into the mat there instead, to save wearing through to the carpet itself.
I find it hard to believe that eve in IF cruise control got stuck that the driver was unable to use the brakes or the cluthc/gears to bring the car to a stop.
It suggests he made no attempt to use the brakes, at all, and it had to be suggested to him to use the handbrake. Brakes will show evidence of usage, if they are used hard at such speeds.
on the call:
"I am trying. It is not stopping at neutral."
court:
"the makers of Skoda, told the inquest that in the five seconds before the crash, the vehicle was travelling at 116mph and the accelerator pedal was fully depressed. He added there was no braking recorded. "
"'There is no indication that there was any error or problem with any of the electronic systems of the car in the five seconds leading up to the collision.'"
"data analysis from the mangled car's airbag systems failed to provide evidence of the defects Mr Gandhi was describing to the call handlers."
There's not much doubt, then.
I'm not aware of a manual car that has an electric clutch that could ignore being pressed if the cruise control decided to go Skynet; far as I've experienced the clutch is a mechanical affair that disconnects the engine from the road when pressed
Further, a manual car that's cruising along will pull out of gear pretty easily. If it's accelerating hard is more difficult but possible
"Not stopping at neutral" implies it's not fully manual though? A DSG or full auto box?
Brakes are also a manual affair that no electric system of the car can override, and I find it hard to believe that the cruise control would ignore a press on the brakes/fail to disengage, but a hard lean on the brakes would slow the car even if it were in gear and accelerating, unless the brake assist system was defective
Rubbing the car down the barrier would have been preferable to using the back of a lorry to come to rest, but perhaps it would have been best to hold the stop/start button down first - all the keyless cars I've driven have an emergency shut off facility whereby holding the start/stop button while the car is active and driving will perform an forced power off of the control systems (but helpfully leaves the steering lock disengaged, unlike pulling the key out of an ignition barrel style car with a mechanically deactivated steering lock)
Whether this person acted deliberately or accidentally it's perhaps a useful reminder for people who have keyless cars; practice doing an emergency shut off of the engine before you really need to use it - find a flat straight road and cruise along, then turn the engine off (nothing bad happens, it just slows down in exactly the same way that lifting your foot off the accelerator does) - give it some seconds then push the start button again to resume. In my Ford I don't have to dip the clutch; the engine was spinning the whole time so the dash simply lights up again, the computer starts supplying fuel and the engine carries on as if nothing happened
