What are decorative black wooden slats infront of house called?
19 Dec 2022
What are those black wooden slats called?
If I want to repaint those what paint should I use?
Thank you.
Mock tudor beams. That's what I call them.
façade beams.
Coat in Zinsser all coat or Dulux Ultimate Opaque black.
Other paints you can use I guess. Depends what on there already
It is imitation half-timbering, an ornamental feature intended to bear some resemblance to 500 year old construction.
I would use a water-repellent stain, as sold for sheds.
If it has previously had some other kind of treatment, it would be better to use the same again. Sadolin is quite popular.
I used Bedec Barn Paint on mine. Wonderful stuff and needs little preparation if any.
It looks more like the house has been braced to combat severe structual problems than a preserved and well rstored home from the Tudor era.
It wouldn't blend in very well on this page
Household equivalent of the half-timbered British estate cars like the Morris Minor Traveller and the Morris Mini Traveller - the latter being the only car I ever owned which got wood worm
(as well as a fair amount of "tin worm")
a car with wood worm - brilliant
out of curiosity, what wood did they use?
Ash, as @footprints said. It was just fixed to the outside of the body on the Mini Countryman, as @JohnD said. Apart from the woodworm it also had galloping wet rot in places.
I did once make-up a set of ash frames for a Moggy Minor estate - solid ash, dowelled. Loads of curves on the bandsaw, but drill the joints  before cutting the curved (I learned the hard way)
