Dumping to the rad but no indication of flow into the T.store (pump off) ??. Would be inclined to change the pump to a smart 4M type like mine (Wilo Yonos Pico) but still doesn't explain riddle of no pump over from the boiler through the T.store vent.I didn't start the fire yesterday and it was too cold to get the pump running - it's a high temp stat, so only runs in the range 50 - 95 degrees. I've started it today and even at 50 degrees, the cycling occurs. For now, I've set the stat to 85 degrees simply to delay/reduce the flow to the thermal store, and I'm dumping to the radiator.
I did ring the company that put the schematic together, and they essentially just followed the Gledhill schematic and recommendations - so I'll give Gledhill a ring on the 3rd Jan, and see if I can get someone in to investigate the issue. He did suggest, that it might be worth reducing the diameter of the vent pipe from store to f&e tank from 22mm to 15mm. So if I did this, and perhaps changed the pump, and perhaps re-instated the cold feed, then perhaps the cycling may be prevented?? I don't know how you guys do your job - it would drive me crazy, lol!
Even with a flow/teturn temperature of 75/20c then the circulating head is only 0.118M or 4.66ins assuming a circulating height of 5M. (gravity circulation)
| Temp/density | 20 | 998.23 | ||
| Temp/density | 75 | 974.87 | ||
| Circ Height | 5 | M | ||
| Circ Force | 0.118 | M | 4.66 | ins |
