- Joined
- 27 Jan 2008
- Messages
- 28,439
- Reaction score
- 3,456
- Location
- Country
Seem to remember drivers hours except for things like gritters, limited to 10 hours, so on a motorway we could expect to travel no more than 600 miles in a day, OK I have travelled from Oran to Annaba in a day with speeds of up to 100 MPH (US speedo) so around a 1000 miles in 1981, but could not do that today.
The main thing is recharging time, most of the points in Wales are either 22 kW or 7 kW, very few DC, and some cars can't charge at 22 kW even if plugged into a three phase charging point, so the larger the battery the longer it will take to charge, from internet
Range also varies, but with the smaller battery not much more than 150 mile range, so if and this is a big if you can find three phase charging points, then 300 mile will need two charges, which mean not 10 hours but 8 hours as 2 hours used to recharge, so around 360 mile limit in a day due to time taken to charge twice.
We have seen this Christmas reports of people queueing to charge their cars, which means in real terms maximum distance is what one can do on one charge.
There were some hybrid cars with a small generator so it extended their range, think BMW made one, but these are it seems no longer made.
However electric transport is not new, we have been electrifying rail transport for years, it does have a huge advantage in that it does not really need to store power, there have been experiments with hybrid, but in the main better to change engines, Australia has been experimenting with rail buses, where in the country it runs on tyres, but in the city on rails, and it seems to lend itself to electric power.
So looking at things sensibly, we should not bother with road transport until all rail transport is electrified, as this could change the whole idea of transport, if you can drive a car to a rail link, then let the train take the strain for the long distance bit, it could even charge the car on the train, so you would only need a 100 mile range, home to rail link.
So between 2 and 14 hours to recharge from an AC supply.Lithium-ion battery capacity is measured in kWh (Kilowatt hours). The average capacity is around 40kWh, but some cars now have up to a 100 kWh capacity.
