A pan or kettle on a gas hob is around 25% efficient
Exactly the point, look at the bigger picture boil a kettle by electric cost you say 10p with 1p worth seeping into the room through heat lossAn electric kettle is close to 100% efficient, the only losses are due to heat lost on the kettle surface, whilst it is heating up. A pan or kettle on a gas hob is around 25% efficient, but gas is around 25% the cost of electric, so assuming the 75% is just wasted heat, there is not much between them. However, in winter, the 75% might not be entirely wasted heat, it can warm the room. In summer use either the electric kettle or hob, in winter the gas hob wins.
I stopped using my electric kettle almost a year ago. Boil on gas.
Yeah, but when cooking on gas I keep the extractor on, especially when boiling water.Exactly the point, look at the bigger picture boil a kettle by electric cost you say 10p with 1p worth seeping into the room through heat loss
same 10p will get you 3x the energy from gas so the equivilent off around 27p worth to the room for free
Didn't make want difference. No limescale buildup problems either.Does it taste better? Boiled kettle water always tastes a bit funny, but I don't know whether that is down to the boiling or the kettle.
If you boil water in a hob use a hob kettle with whistle. This loses less stream than an electric kettle.Yeah, but when cooking on gas I keep the extractor on, especially when boiling water.
Where does that heat go?
Either way, kettle for convenience for me. Who cares about efficiency
