Well if you had only one point at the half way stage per cable length it would be a para path therefore having the merits of a 5.0 live conductor or 4 , another ring I suppose.
Exactly.
Anyway Ring Finals comply and have their uses and have pretty much passed the test of time really.
That's why I'm essentially 'neutral'. Both the pros and cons (relative to radials) are pretty trivial, and roughly balance each other
But out of favour with a few (or many) understandably so.
Indeed - but I don't fully understand why some people's 'anti' views are so strong - as above, I really don't thing there is a strong reason for favouring one approach or the other.
The point was though it`s a Ring (Final) Circuit in the installation but you could have a Ring Main in the street or in the transmission distribution area and the Main and the final are different and should be differentiated.
I agree. That's why I've been saying that, although some of the hypothetical within-installation arrangements he mentioned could have the same electrical characteristics as a distributor's "ring main", I personally think it's better to not use that term within an installation. Having said that, in reality if someone talks about the 'ring main' supplying sockets within their house, we all not 'what they mean'.
Like I also said "Spur" is often wrongly used too. .... Actually so is "Live" , Line and Neutral are both Live (Not, by convention, a PEN or CNE Neutral though). A Live conductor normally carries current as part of its intended function or really the function of the cable etc . a cpc (Earth) carries current of an earth fault.
All true, and I agree that it is reasonable to explain the 'correct terminology' to those who make these mistakes but, again, we all know what they mean when they talk of "spurs" or "live".
The electrical industry itself is not immune. For example, I frequently mention my personal dislike of using the term "continuity testing" to refer to quantitative measurement of small resistances ... and it also rather seems that it was the industry itself who were responsible for the ridiculous "plug top" term to describe a plug
There is also an issue when the industry continues to use its own 'correct' terminology in relation to things relevant to the general public when the vast majority of the general public use, and understand, different vterminology - "low voltage" and the lamps/bulbs issue come to mind.
One could go on about such things for ever but, as I always say, what matters is that we have a means of 'clear and unambiguous communication', whatever the considerations of 'right and wrong'
