is this thread M6 or M5?
It's handy to have a small stock of nuts and bolts, of known thread sizes, to use as thread gauges.
sounds like a plan.OK guys thanks, I'll try this , the following bolt going in from below the housing, so the thread appears at the top
High Tensile Set Screw
High tensile zinc plated steel. Use when a full threaded bolt is required.www.toolstation.com
then a nut on top to secure the bracket to the housing. So thread remains exposed
Nylon Lock Nut
Zinc plated with nylon locking insert. 108 piece selection pack available (code 60090).www.toolstation.com
Then screw this thing on to the exposed thread (connects to the engine cover)
It's handy to have a stock of nuts/bolts/washers so you can fix something there and then without having to go down the shops or wait on the post!It's handy to have a small stock of nuts and bolts, of known thread sizes, to use as thread gauges.
btw this is what it looked like before I lost the bolt! (The one on the right - at about 3 o clock position)
I’ve got a massive big bucket in work full of nuts and bolts of all sizes. I don't know where they came from…….It's handy to have a small stock of nuts and bolts, of known thread sizes, to use as thread gauges.
I had 3 problems along route. First time I've changed the fuel filter on this car (Ford Grand CMAX 1.5TDI 2016), but I have changed fuel filter on a previous car ~ 10 years ago!sounds like a plan.
And the important question. Have fun with the filter ? It start ok after new 1 fitted ?
harsh but trueNeeds polishing.
Very brave. Any problems my car goes straight to the garage. I took a look inside the engine bay on our recently bought car. I shuddered and closed the bonnet quick.I had 3 problems along route. First time I've changed the fuel filter on this car (Ford Grand CMAX 1.5TDI 2016), but I have changed fuel filter on a previous car ~ 10 years ago!
1. (Obvious one). I dropped a bolt into the engine bay.
2. Struggled to get one of the fuel hoses out. Turned out you pull a clip up (with flathead screw driver), whilst simultaneously pushing the other part of the clip down and pull the house out. Easy when you know what to do!
3. I got a MANN filter from Euro car parts, turned out it was the wrong part. Had to go back and the Bosch one was the right one.
Aside from that all went well. Started fine. I syphoned out the old diesel from the housing and gave it a clean. I did fill up the filter housing with diesel as part of the change. These fords dont prime the fuel automatically.
Next time I expect it to go swimmingly well. First time is always the hardest!
I know what you mean. I only do minor things, oil + oil filter, air filter, fuel filter, pollen filter and maybe brakes. I wont do anything bigger (e.g. timing belt). And I have a car that's out of warranty (I bought it recently and it had done ~100k) . You of course need to invest in the appropriate tools - can get expensive. One of the benefits of the modern age though is that there's usually a youtube vid explaining how to do stuff! and of course forums like this. I followed thisVery brave. Any problems my car goes straight to the garage. I took a look inside the engine bay on our recently bought car. I shuddered and closed the bonnet quick.
On a dull day, you can tip them out and sort them by diameter and length.
That's exactly it. That's a great site btw.. thanks for sharing, bookmarked!Is this it?
If so, M6
If you click on the part number it lists other vehicles the part is used on.
Should be able to get one from a scrapyard/ebay breaking a suitable model.
