Face brick water absorption below DPC, advice required
4 Jan 2009
True North
Could someone advise on the best type of brick to use below DPC on a house. I need to select a black brick for 3 courses below DPC, 1 course will be under the side path level and the other two courses will be above finish ground level up to DPC. Some searches say 4.5% and others say 7.5% water absorption is required for below DPC.
I was recommended the following brick which is 12% absorption, and is F2 S2.
My facing bricks above DPC are <10% and F2 S2.
I don't want them popping because of frost in winter.
Blue class B engineers with dark coloured mortar? Or is that not black enough
Anything F2 S2 rated will do. I'd go for Staffy blues as said. (Edited)
Staffordshire blue smooth were my original preference but a guy who sources the bricks for a living at good prices can get them black ones in packs of 400 plus any extras I might need. I'm going to calculate how many but it was looking like 800 and staff blue's were in packs of around 560 depending on which brand, I don't want loads of spares so a stocked item is probably best.
I think blacks would go better with a light grey brick & anthracite windows than a blue but not if the frosts going to damage them. It's quite wet the ground around where I'll build so need good drainage, thats why i wondered if the 12% was worse than a 7% if both marked as S2 F2
