New build - no floor vents
20 Jan 2023
My house, and the others on the estate, built in the last 4 years, doesn't have any vents beneath the floor on the outside. I see a lot of houses elsewhere of a similar age with vents on the outside at ground level. I just wondered why some houses had them and others didn't? I assume it varies depending on the floor base used?
Curiously, I also notice that two thirds of the estate use blue engineering bricks for their DPC, whereas the other third (including my house) uses the black plastic sheet instead for the DPC. Other than running out of engineering bricks part way through building the estate, I wondered why this might be. The houses that use the engineering bricks are closer to the SUDS balancing lagoons so I wonder if it's something to do with flooding, but I doubt it.
I know these questions are a little random, but the original builder has moved on and isn't around to answer these questions :-)
Houses have ventilation when the floor is suspended with a void underneath.
The houses with blue engineering bricks will still have a plastic DPC the same as yours
Thanks, I thought the engineering brick was instead of the plastic DPC. If not, why would some have the engineering bricks and others don't?
No they’ll still have a plastic DPC if they’ve been built within the last 4 years.
Probably blue so that the houses look different and you don’t have a new estate with every house identical
Engineering bricks may or may not be visible due to variations in the ground levels.
Perhaps, though it would be unusual for a developer to use one system for flooring for some houses and another for the others.
Just to clarify I don't see vents on any of the houses here, just two thirds with blue bricks and the other third with no blue bricks
You prob have concrete floors. No need for vents.
Blue bricks are used for fashion these days. Just a different style thats all.
bricklayer says "weve run out of bricks"
site foreman says: "just get up to damp with face bricks, we cant have any hold ups"
