I need to replace an old oven with a new one, but all attempts to find one that will fit the cupboard space have so far failed. Apart from the cupboard being fairly shallow, there's a gas pipe in the way and so I may arrange for it to be moved, but how can it be moved without ripping out the cupboard to the right of it? Here are some photos. Any thoughts?
The issue is twofold; first the length of pipe from half way down the cupboard reduces the depth to only 540mm, then there is the connection to the hob, which reduces the depth further to only 470mm. A lot of ovens have a "cutout" on the top of the back of the oven, to allow for gas pipes, however, this pipe connection seems to take an awful lot of space, and extends 65mm down into the cupboard space.
The pipe itself is around 35mm from the back wall and this is due to the piece of wood forming part of the cupboard structure and with which the cupboard is screwed to the wall. If this wood wasn't there it would allow the pipe to be moved 20mm further back, providing a depth of 560mm. Unfortunately, this piece of wood is screwed into each side panel so can't easily be removed!
