Hi all
I need to replace some guttering for a customer when I re-paint their exterior. There is scaffolding because it is being repointed. The house is Victorian.
The span is approx 6m.
I think that the current black plastic guttering is a "standard" half round. It has one union join, which leaks. The exit pipe runs in to a soil pipe boss (via a running outlet) and uses a rubber flexible connection (the type with jubilee clips).
He has asked for a bigger capacity guttering. Apparently, if the rain fall is particularly heavy it jumps out of the guttering. Looking a the roof space I suspect that it more likely that the gutter needs clearing out from time to time. Nevertheless, I will provide him with what he asked for.
From what I have read thus far... the Flowplast Deep flow might be ideal.
Given that the new guttering will be slightly deeper, will the soil pipe boss be at the wrong height. If I move the running outlet further away from the soil pipe, will that suffice? From memory, the running outlet is about 30cm from the soil pipe.
Unfortunately I don't have any photos on me at the moment.
The customer has categorically stated that he doesn't want the join where it currently is- it leaks just above the kitchen door.
I would be grateful for any supplier recommendations. I will probably order two 4mm lengths to give me a bit of wiggle room, so it needs to be delivered to site (Ealing, West London).
I am guessing that I additionally need about 7 clips, a union, the running outlet, a short length of 68mm, and an elbow. Based on the site I looked at earlier, that is about £80 (inc VAT) plus £12.50 for delivery.
Is there anything that I may not have considered and are their other sites or brands that I should consider?
Thanks in advance.
...Oh, as a follow on, are leaf guards effective, or do the leaves sit on the top of the guard and cause the water to run over the top of the guttering anyway?
Thanks in advance.
