replacing existing rotary dimmer with vpro eclique
4 Feb 2023
Hi all enclosed the the wiring picture of a standard two way rotary dimmer with a two way switch, i want to change for a vpro eclique touch dimmer- master and slave not sure how to wire it though!
On the switch that has two cables in L1 and L2.
First of all, mark the conductors so you don’t mix them up.
The pair of wires that are in L1 goes to the LIVE terminal on the MASTER dimmer.
The other pair goes to LOAD on thd naster dimmer.
The black goes to the S terminal.
On the slave dimmer, black goes to the S terminal.
The other two wires go to live and load.
If your dimmers have metal front plates then you must connect earth to the plate.
That should do it.
The black goes to the S terminal.https://www.varilight.co.uk/leaflet...ro_Multi-Point_Remote_Dimmer_Instructions.pdf
That should do it.
Thank you
does this correlate with tyhe instructions as per the above?
