- Joined
- 14 Feb 2005
- Messages
- 102
- Reaction score
- 16
- Country
I apologise for the length of the message.
About one year ago we had a Sanispeed pump installed on the ground floor of our house to take the washing machine water to the sewer system (it was previously linked to the rainwater system). Since then there have been intermittent very strong sewer smells outside the house (I blamed the neighbours as they have a drain at the front linked to the sewer, but everybody does and there is no issue, and we never had this before the pump).
I put pictures of the plumbing and my attempt at a drawing. Red is as built plumbing and green is additional. The black pipe on drawing "Section 1 Garage" that joins the WC ground floor pipe is from the pump. There is also the condensate pump from the boiler attached to the same pipe. The total distance from the pump to where it joins the pipe is about 7m and it rises up to about 1.9m.
There is no non-return valve or anything on the pipework from the pump.
My question is, the pipe that connects to the pump is linked ultimately to the original pipe in the kitchen that goes to the regard under the house that links to the sewer. Could the pump be creating a sort of "backdraft" that is bringing back the smell? Or does it not work like that? Because this issue literally started as soon as we had the pump installed. It only smells outside. There are no manhole or access points to the sewer pipes on our property and we are at least 100m from the nearest manhole so it has to be coming from us or next door.
Also, should we worry about the state of the pipe in the kitchen?
Any input appreciated.
Gill
Gill
