Size is Everything
11 Nov 2020
Middle Earth
What would you guess is the thickness of this tile?
I want it to be 6-7mm and have an idea that it might be but websites often omit this measurement from the description.
If only i could order a one-size set but the walls are wonky and i'm trying to fit them without resorting to many cuts.
A set around the window, for instance, needs to be 5-6mm; then under the window can go 6-7mm, then along the other wall they can be 7-8mm.
Sounds picky, yeah?
Trust me, there's method in this madness.:mrgreen:
Ahh, found it:
99p for a sample, cheap coaster! ;)
Ahh, found it:
That's the chappie - i still want to say it's 6mm which would suit the wall 'neath a window.
It has a textured surface so i wouldn't put your beer on one if i were you.:giggle:
Have you contacted the tile supplier for the info?
Aye, tried phoning but after about ten minutes the call was cut-off...so i called again and left it ringing til i had to use the phone for another call. Sent 'em an e-mail. No reply. Yet. Scrrrrrrew it.
