Hello!
I want to have my consumer unit replaced and have already bought a new 10 way Fusebox CU with surge protection, 6 mini RCBOs, 4 blank modules and an intumescent strip in readiness for an electrician to install. However, I'm looking for advice from professional electricians only please on this forum BEFORE I instruct an electrician to do the work. This is because I've had several electricians tell me conflicting stories as well as quote vastly different prices for what seems to me like 2 to 3 hours work, maximum.
Please see attached photos: The feed from the meter box outside the property consists of a 3-core (1 spare core) MIMS cable which comes through the breeze block wall into the property where it is terminated on Henley blocks inside a black steel junction box (I've left the lids off for the purposes of the photos). From there it splits with 2 sets of tails: 1 goes to the old main consumer unit above it and the other goes to the white "garage consumer unit" to the left of it, which is now redundant and can be removed.
What I would like to know is this: Does the MIMS cable have to go to such a junction box before going onto the new consumer unit or can it be terminated directly inside the new CU? I'm trying to tidy up an unsightly mess in my entrance hallway and would like to have as few items of electrical hardware on show as possible.
If the MIMS cable must first terminate in a junction box, then I propose to have the current one moved a few centimetres to accommodate the new taller CU or better still have it replaced with a smaller one if that's possible.
Your thoughts please, professional electricians?
