Touching up Matt paint ends up glossy?!
20 Feb 2023
Hi.
New here so hello to everyone. Hopefully someone can guide me on this paint issue, which I've googled, but not found a sound solution. I've touched up the walls on the landing and stairs, using Dulux easy care white mist, due to a few light scrapes etc. However, as can be seen in the picture, despite using the same paint, it's left a ln annoying 'sheen' finish, instead of a Matt colour, which can be seen clearly in the lighting, where it's reflecting the light far more than the original paint. I stirred it, applied with a roller...any thoughts? Ignore the blue tape.
Did you use the same application tool? If the walls were done with a roller and the touch up with a brush the different texture will show up.
As per my description, I used a roller, same as when the job was originally done. Only time I use a brush is for cutting in, so it's a mystery....
Is it the same tin? Some paints suffer from "flashing" or "halo effect" worse than others. Try a search on those terms, sadly the usual answer is to repaint the complete wall. :(
Wow, same time tin. It's mad that for a couple of small marks you end up having to paint a whole stairs wall. In future ill settle for leaving the marks on the wall cheers anyway
Use a foam roller.
When you draw a sun you make sun beams. Do that pattern with roller. Short and long strokes.
Easycare won't spot repair well
