The idea is presumably that they 'prevent', rather than 'remove', condensation - by removing air containing a lot of water vapour before that water vapour condenses on cool surfaces.If fans are so brilliant at removing 'condensation' from a room then why do they not remove it from a duct?
Once condensation has happened (i.e. water vapour has turned into liquid water on walls etc.), there's not all that much that a fan can do to remove it, other than (perhaps) replacing air in the room with air of lower humidity, thereby encouraging evaporation - but such evaporation is a pretty/very slow process.
Yes, maybe - and, if so, that's a more fundamental problem than any 'condensation'.From the description in the OP it appears that the top of the duct is not preventing entry of water and dirt from outside.
