old water tank in loft - Safe to remove?
The boiler is a vokera linea 28, and the pressure gauge is sitting just above 1 bar.
For another post, the presure drops every time i top it up (no sign of leaks)
Hi
roughly on this subject I have an old dry water tank in the loft is it safe to remove the pipes around it as I’m trying to floor the loft
thanks in advance
Hi
thanks in advance
Not a bad start for a first post. Resurrecting one from nearly 16 years ago, but hey ho.
If the tank is dry and the pipes have no water in them then yes, you can rip it out.
BUT! make absolutely sure the pipes are still not being fed with water before you cut them/remove them.
