- Joined
- 2 Mar 2023
- Messages
- 12
- Reaction score
- 0
- Country
Finally have some responses. Not sure what to make of them but am waiting to see what the patio door installers say.
What's a 250x300x40 m/s plate?
SE made a mistake and changed this to 250x300x20mm
Why not use a 152x152x23 instead of 203 x 203 x 46?
Cost; 152x152x23 will need a plate to be welded to support the solid wall, 203x203x46 will not need it so it will be cheaper to use that
Additionally, the SE insists that the new boundary wall we'll build for the side infill extension can't be thinner than 365.50mm because "Building regulations changed last year in June, so minimum insulation needs to be 165mm to comply with the new regulations."
What is the thinnest external wall that can built which meets regulations?
I can't find anything showing those measurements but am seeing u-value numbers. Is there any validity in what he's saying about 365.50mm? At this thickness the room in the extended area would be incredibly narrow and not worth building.
SE's 0.18 W/m2k Wall components
Facing brick 103mm
Aircrete blocks 100mm
Rockwool insulation 100mm
Celotex PIR insulation 50mm
Plasterboard 12.5mm
Facing brick 103mm
Plasterboard 12.5mm
