Can I plug a C19 16A cable into a wall socket
20 Oct 2020
Am I able to plug a 16A C19 cable into a UK standard plug socket?
The socket forms part of a 32A ring circuit.
This would be power an Uninterruptible Power Supply in my garage.
Thanks in advance.
Roughly 2000w.
The load of my equipment is no more than 500w max but I was thinking that a larger unit would power 500w for a longer duration in the event of a power cut.
So maybe it's a c19 with a 13a fuse for that rating (similar to a kettle).
Has the cable got a plug on it?
A 16A plug will not fit a 13A socket
But you can cut it off and fit a 13A plug.
If I understand you correctly the load of the appliance is less than 13A
So the 16a plug on the c19 is a different size to a normal domestic 3 pin one?
Yes the load is way less than 13a.
However what about when the ups is charging?
Yes, as in the link above.
If you are going to cut the end off of a C19 lead, to fit a UK plug; check the cable size first - some of the C19 leads I have seen, have cables that are a bit too thick for an easy fit into the cheaper UK plugs.
Have you got the lead yet?
If it had a 16A plug, it could look like this:
If it has a standard 3 pin plug on the end already, like this:
Then it will plug straight into a standard socket.
The black part.
Yes!
No, only UK standard plugs will fit.
There, that's that cleared up
Not really, the OP can have a 16A lead with a 16A C19 connector, and if it is fitted with a 13A plug, then it will fit, but then we're just arguing semantics :)
...and we still don't know what the OP has, or hasn't got!
