What size Flex to use for new light?
10 Apr 2005
Avon
Hi
I am replacing a ceiling light with a new light. The existing light fitting comes with fixed cable wire, which has then been connected to a terminal block. This terminal block has the loop in loop out and switch wires going into it ( see picture).
My new light doesnt come pre attached with any cable . So i assume i need some flex to attach my new light to the light fitting itself and terminal block in the ceiling. My question what size flex? I have some 1.5mm Flex . I read that 1mm to 1.5mm would be fine but i am not sure . Pls can anyone advise
just remove the cables from junction block on the new lamp amd connect them to the junction block the old light is connected to.
All done now . Pics of the new and old. Thanks everyone
