What time switch.
29 Sep 2009
Glasgow
I’m struggling to find what I need because I don’t know what it is called.
I want a time switch that has four terminals, or five if it needs an earth.
1 & 2 ----- Live and Neutral to drive the clock.
3 & 4 -----Two other terminals which are switched but totally separate from the power that runs the clock. I want to switch a separate circuit.
I’ve fitted time switches like this many times but can’t find one to buy now.
It can be basic; I only need one on and one off per day and it will be the same times every day.
What am I looking for?
Just a standard 24hr clock non digital ? I’ve got a couple if you want them if you pay for the postage ….as per picture
Never worked out why, but time switches often called programmers. Used a lot with central heating. As said want a volt free programmer. Also check the current rating, some are only 5 amp.
The name comes from the fact that inside the unit none of the switching contacts have any connection to a voltage source.
Must agree with @EFLImpudence on this, if there is no voltage at the contacts, then they do nothing, variable voltage contacts yes, or isolated contacts yes, but no volt contacts is a silly name, but now accepted like many other electrical names like electronic transformers.
That is obvious. But when contacts inside a module have no connection with a voltage inside the module then the voltage on the contacts has to be supplied from a source external to the module. Until they are connected to that external source the contacts do not have any voltage on them.
As does that voltage with which they have no connection.
And then they do.
