I think I understand the feedback - Attached is the final layout of where the magnaclean will be fitted - It will only catch the radiator return which I suppose is better then nothing - I stopped thinking to put it on flow based on your feedback
As was suggested .... Majority of any corrosion will be from the radiator circuit, so without actually changing the pipework to bring the rad return in higher up from the pump and then allow the vertical return before the pump to be extended to fit the filter, then your location should be fine
Also ... put cleaner in, run for a week or 2, drain/flush/drain/flush till it runs clear then fill & inhibitor then warm/circulate the CH system once a day ... check and clear mag filter after a week, keep doing that until it stops catching any major amounts of crap.
Just saw that magna clean have a new 2 in 1 product that includes a wire strainer for debris. It just seems so obvious why particle filters weren’t included in these types of products to begin with.
Most filter these days incorporate a particulate filter as part of the design, usually in the form of a central basket type arrangement or the way the water circulates in the filter.
You said you already had a Magnaclean? I'm sure all of them capture particulates as well as ferrous material.
Nah. The original magna clean pro1 only had a plastic sheathing, no filter and the pro 2 has a filter but it captures nothing particularly well. Drained out a system with underfloor over a white bucket and sand deposited at the bottom.
