- Joined
- 27 Jan 2008
- Messages
- 29,080
- Reaction score
- 3,563
- Location
- Country
New outside light, at moment using a compact fluorescent lamp, but will be looking at a smart LED lamp, however in the main they shine up, and lamp is of this
general design, although not the one shown, and the lid is over sprayed with mat black, so the light is not directed up the drive as required, so considering some reflector if only tin foil. But near every lamp I look at seems to be missing any reflector, I have one battery powered lantern with a special parabolic type reflector in the top, you can see some thing here
where some cone shaped bit in the top tries to redirect the light, to what effect is hard to say, so simple is a piece of hexagonal cardboard covered in tin foil placed in the top, but how much will the reflector help?
I have five other carriage lamps around the house, most use a bulb, but one is integral with the LED's in the top facing down with frosted glass, and it is so much better than the rest, but no point re inventing the wheel, I am sure others have already fitted reflectors, so what have they used?
where some cone shaped bit in the top tries to redirect the light, to what effect is hard to say, so simple is a piece of hexagonal cardboard covered in tin foil placed in the top, but how much will the reflector help?I have five other carriage lamps around the house, most use a bulb, but one is integral with the LED's in the top facing down with frosted glass, and it is so much better than the rest, but no point re inventing the wheel, I am sure others have already fitted reflectors, so what have they used?
