13a or 16a required for this oven?
NHW
21 Jun 2013
so the oven that im looking at is the Samsung NV7B5750TAK
https://www.samsung.com/uk/cooking-...-steam-5series-dual-cook-flex-nv7b5750tak-u4/
On the first product review someone says "Everything you need in one compact oven - and works on a 13a plug too!"
But i cannot figure out if according to the manufacturers instructions if it is recommended to be hardwired? as it says on the official instruction manual for the oven:
"Plug the oven into an electrical socket"
which im assuming that their recommended instruction is to plug it into a normal 13a plug socket?
The write upon the Samsung website is rather confusing, says works of 13A plug but
Power/Ratings​
  • Power Source230-240 V ~ 50 Hz
  • Output Power3650-3950 W
  • Energy Efficiency ClassA+
  • Oven Temp. Ranges (Single)30~250 (Grill 100~270)
  • Oven Temp. Ranges (Upper, Lower)40~250 °C
  • Oven Temp. Ranges (Twin)40~250 °C
Personally I think that is too much for a 13A socket unless it cannot be used at the maximum quoted but as I said a bit confusing. Perhaps someone else may be able to explain it.
Power/Ratings​
Exactly, normally ive read that double ovens are 16a and hardwired.
But im just worried that if i buy it, then something goes wrong. The fact that I havent followed the manufacturers instructions means that warranty will be void. Even though like you said the manufacturers official instructions have made it very unclear.
Or maybe because it is a new efficient type of oven that it draws less power? totally plucking that out of thin air as i know nothing about electrics lol but just thought that might be a plausible reason?
A first look suggests the 3900W is the combination of the convection, upper and lower grills altogether - a combination that may not be possible (or desirable!) all at the same time!
Some further investigation may be necessary...
A first look suggests the 3900W is the combination of the convection, upper and lower grills altogether - a combination that may not be possible (or desirable!) all at the same time! ... Some further investigation may be necessary...
Indeed, not to mention 'diversity', even if everything can be 'switched on' simultaneously.
There are after all, some induction (and maybe other) hobs with 'intelligent controllers' that can be used with a 13A plug.
I have found myself in a similar situation in the past and decided to err on the side of caution.
I am not an electrician and so decided to run 2.5mm T&E to a 2 MCB enclosure and then fitted a 16A MCB and a blanking plate and a suitably rated flex down to the oven.
I was aware that diversity meant that 13 amps might be OK but I didn't want my mum phoning me up on Christmas day, complaining that the 13A plug behind the oven had blown its fuse.
A tenner for the 2 mcb enclosure and the 16A MCB, well worth the piece of mind. I fitted the enclosure in the unit above the oven. Previously the kitchen fitter had just used a plug behind the oven.
I am not an electrician and so decided to run 2.5mm T&E to a 2 MCB enclosure and then fitted a 16A MCB and a blanking plate and a suitably rated flex down to the oven. .... I was aware that diversity meant that 13 amps might be OK but I didn't want my mum phoning me up on Christmas day, complaining that the 13A plug behind the oven had blown its fuse.
In reality, of course, there is virtually no difference. It takes about 23A continuously for 1 hour to trip a B16 MCB, and about 22A continuously for a 13A BS1362 fuse to ever blow.
